kyocera 5035 hdd format error
  • digicor
    • Jul 2008
    • 1154
    I have a KM5035 with this hdd format error,
    i have ran scan/chk disk.. no bueno.. format hdd... still no go away
    is there a service on/off for the hdd? the client is not printing to this mach so it wont matter
  • digicor
    • Jul 2008
    • 1154
    i removed the HDD for now
    • Absurd
      Just a brick in the wall
      • Oct 2007
      • 118
      this was a problem with the hdd itself. and your right if your talking about the printer hdd then as long as they dont send any print job or group of print jobs larger than standard memory you should never have another problem. I have removed a hdd in the past for this very reason and has never been an issue. if they want mail boxes or any other special print storage than you will need to replace the old hdd.
      Southern Duplicating of Mississippi
      PSN: DrAbsurd (if you know you know)
      "If you love wealth more than liberty, the tranquility of servitude better than the animating contest of freedom, depart from us in peace. We ask not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains rest lightly upon you and may posterity forget that you were our countrymen." [Samuel Adams]
      • fatthyzz
        • Feb 2010
        • 10
        Perform sim 906 after that system error appear press 10871087 then do sim 24
        • taskalfaman
          • Nov 2009
          • 137
          PS inside?
          externally format hdd with your pc!!
