5050
  • schleifer
    does anyone know the engineering code to get into simulation? 30363036 and 23412341 do not work.
  • fatthyzz
    • Feb 2010
    • 10
    Press status key then 30363036
      • 23008
      warning: I've been told by other techs that if you enter that engineering code it performs an all clear on the machine. All customer data and machine settings are wiped out. Be sure that is what you want.
      • fatthyzz
        • Feb 2010
        • 10
        If you do you will just get into simulation mode and don't perform simulation 20 which clear all data.
        • Alexsis
          Re: 5050
          Is there any else engeneering code that works?
          • ss12
            • 289
            Press job status then 1087 1087
            • Alexsis
              Re: 5050
              Yes, and alternatives for 3036?
