Kyocera 4035 prob
  • RRodgers
    • Jun 2009
    • 1947
    Kyocera 4035 prob
    I'm having probs with scanning. I assume it's the HD. Question is, where in the machine is the HD for the scanner? I took out the one in the back (slides right in) and fired up and the box, both the printer and the scanner came to ready... so I didn't think that was it.
    TIA.
    Rob
    • 23010
    That was it. It comes to ready, but errors out when you try to scan. It's a Toshiba HDD2D10 40GB 5400RPM 2.5in IDE laptop hard drive. =^..^=
    • RRodgers
      • Jun 2009
      • 1947
      Thanks man. I'll replace it.
      • vikingmita
        • Nov 2008
        • 163
        the one that slides into the print system (right side) is only for print, the xx35-series does not have/need a scan(copy) hd, it's an option.
