PF-750 can't open drawer
  • Jimbo1
    • Mar 2008
    • 845
    We have had a couple of PF-750's lately that have developed a problem where when the right tray runs out it tries to push it on up like there is paper in it and you can't open the drawer. That is you have to turn the machine off and tap the front of the drawer until it drops down a bit. We put a lift motor in one and today one tech putone of the cork pads from an adf where the roller meets the tray. Those have been a couple of temp fixes but we would like to know if anyone else has had this and knows a real fix. It ain't firmware either.
    "Some days you get the bear, some days the bear gets you."
    Cdr. William Riker
  • taskalfaman
    • Nov 2009
    • 137
    hi,
    problably the left drawer is skew(not horizontally). reposition this tray with the belts and the problemwill be solved.
    PS. there is a kind of Service bulletin for this!!
    have fun
    • Jimbo1
      • Mar 2008
      • 845
      Would you have a link to that? We also had a tech install one of the cork sep pads from a ADF in one and it seems to be working. We can't see anything wrong with the tray.
      Cdr. William Riker
      • Jimbo1
        • Mar 2008
        • 845
        Any body got the bulletin on this? I guess that guy posted and dropped off the face of the earth.
        Cdr. William Riker
        • Jimbo1
          • Mar 2008
          • 845
          I would really appreciate if anyone can enlighten me about the bulletin previously mentioned by taskalfaman.
          We have lloked through the bulletins and cannot find it. However, experience has shown sometimes the are bulletins in Europe that aren't posted in the US.
          Please throw us a bone.
          K?
          Cdr. William Riker
            I found this on the eu site, it maybe what your looking for,
            SB-8543..pdf
            • Jimbo1
              • Mar 2008
              • 845
              Sorry we already had that one and it's a different thing. This is when the tray tries to raise too high and you can't open the drawer. You have to turn the machine off and tap on the front of the door Fonzie style to get it to open.
              Need the bulletin if it's there. Taskalfaman are you with us???????????????????????????????????????????????
              Cdr. William Riker
                • 23010
                You got me curious, so I dug through all the bulletins and Helpdesk records. I found exactly nothing that mentions the tray lift belts. Sorry. I'm no help. =^..^=
                • Jimbo1
                  • Mar 2008
                  • 845
                  That's ok and thanks to all. Don't know that it's belts really and we swapped the feed unit out thinking it may be a sensor issue. So far it's in three machines at two different locations. Two different companies as well which takes some of the human factor out...but maybe not all.
                  Cdr. William Riker
                  • dickierock
                    • 252
                    Hey Jimbo1, I checked the Kyocera, Utax, and the Olivetti tech sites and there is no mention of any related bulletin so im guessing it doesn't exist. Sorry I can't be of more assistance..
                    • Jimbo1
                      • Mar 2008
                      • 845
                      Thanks anyway...some days you get the bear...some days the bear gets you.
                      Cdr. William Riker
