As you probably already know, the CFxxx codes are secret engineering codes that you must forget the moment that you see it. This is an irritation with me, that Kyocera would use certain error messages then refuse to tell us what they mean.
I've never seen those specific codes associated with a TASKalfa. If this was a Falcon III the CF215 would be accessory firmware error, and CF46F would be a HDD image process error.
That's about all I've got. I hope it helps. =^..^=
CF215 occurred when the Start key was pressed after A5R original was set in DP, B4R was selected as media, AMS/B&W/automatic density were set in double copy.
The solution is in firmware version Firmware Version 07.01.0030 wich you already have i would try to firmware it agian
see her
Main 2H7_2F00.003.061
MMI 2H7_7000.003.050
opt_Language 2H7_81BR.001.007
Browser 2H7_F000.001.011
Engine (high) 2H7_1000.003.006
Engine (low) 2JZ_1000.003.007
FAX 3MB_5400.001.016
DF780 5JA_9200.002.006
<Changes>
- Support for FAX System (Q)
- Support for the Key Counter
- Mode to prohibit output in the evening
- Black & White printing when the color toner is empty
- Add the mode on the “Original Image”
- Support for output to the left tray
- The measure against CF25E
- The measure against CF4AF
- Change the order of the panel display for the USB host data
- The measure against C6200 (Fuser heater 1 edge break)
- The measure against C8350 (Centerfold side registration motor 1 problem)
- The measure against C0640 (Hard Disk Drive problem)
- The measure against CF526
- The measure against CF46F
- The measure against CF215
- The measure against CF278
- The measure against CF245
- The measure against CF59B
- The measure against CF515
When a new version is submitted, the older firmware version is removed, or so I have been told. I keep all the versions (the ones I download anyway) in my computer. I haven't been in this business long, so my 500 series firmware only goes back to version 7. I plan on keeping as many of the older versions as possible. Ya never know when you might need it.
Just a few days ago Kyocera released v. 8.01A 03-01-10
Don't load anything before v. 5.0 (a lot of bugs were fixed in v. 5.0). There's 2.01, 3.0, 3.02, 3.04, 4.0, 5.0, 6.0, 6.03, 7.0, 7.01, 8.0, and now 8.01A
Personally I don't see any end in sight. =^..^=
