C1950 error code on CS-3225
  • lorenrupe
    The Great Land
    • 57
    Have had this issue with this machine off and on for some time now... I read in a past posting to clean or replace transfer belt speed sensor, where might this be located? Is it part of the transfer belt unit or is it internal to the machine? please help!!!
    Loren Rupe
    Valley Business Machines Inc.
    • 22997
    C1950 is a transfer belt EEPROM error. Most often when you get any EEPROM error it's something fairly mundane, like the connector not completely made, or a broken wire at the connector. The way I would diagnose this one is to swap in a scrap transfer belt assembly to see if the code will clear. From there you can decide if you want to fix the original pigtail, or just leave in the scrap unit. =^..^=
