KM 2050 "data capacity is over limit to send email scanning"
  • wholesaledirect
    • Nov 2009
    • 17
    What does this code mean? What's the solution?
    Gary
    www.WDCopiers.com
    Wholesale Direct Copiers
    Orlando, FL
    877-740-7887
    GaryG@WDCopiers.com
    • 22930
    This is an easy one. The default limit for email attachment size is 1MB. A more useful limit it 20MB.
    Go to the web interface, scanning, email, SMTP Setup. You'll see a line for email attachment size. Either its Low/Med/High/Unlimited, or a numerical value. Select High or 20000KB (=20MB), then Submit.
    • wholesaledirect
      • Nov 2009
      • 17
      These machines are new to us. Would you mind explaining the process of logging on to the web interface. I assume you just need to put the IP address into explorer and get in that way.
      www.WDCopiers.com
      Orlando, FL
      877-740-7887
      GaryG@WDCopiers.com
        • 22930
        Yes, that's correct. If my memory serves me correctly there are two network card on this model, scanner & printer. The NIC you need to log onto is the scanner card.
        The separate scan card is arranged a little differently than the menu I listed. Look for Email Basics or SMTP Basic. =^..^=
        • B0265
          • Jan 2007
          • 718
          E-Mail Basic Setting > Data Size
          You can select Non-restricted, High (2048 KB), Mid. (1024 KB) or Low (512 KB)
          • denko
            Re: KM 2050 "data capacity is over limit to send email scanning"
            change the file type to pdf when on scanner network mode
