Kyocera 1128 trying to set up to scan
  • Lasman26
    • Mar 2010
    • 8
    I have installed all drivers ok but, scanner can not connect? Yet it is working in device manager. Thanks for your help..
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1889
    I assume by device manager you're hooking it up USB ? Did you install the TWAIN driver ? I'd personally intall it on the network & scan to a folder or email. Need a little more info to be of any help.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • Lasman26
      • Mar 2010
      • 8
      Hi Tony
      Thanks for your reply. When setting up it automatically installs WIA Driver? We are working with windows XP.
      • tmaged
        • Oct 2008
        • 1889
        Originally posted by Lasman26
        Hi Tony
        I'm still trying to figure this out for a customer. It looks like the WIA is for Vista only. I've attached the guide for it. If I read it correctly you have to scan to the document box & acquire the image via the TWAIN driver from there. This will only work USB, not over the network.
        Hope that helps !
        -Tony
        www.dtios.com
        • spandx17
          • Mar 2010
          • 30
          Here is a link to the TWAIN driver:
          Managed Print: Simplified is Kyocera
          Just Install Driver, Go to Program Files/Kyocera/TWAIN driver Settings. Click Add, Give Scanner a name, Select Model, the OK.
          Should be accessible now. I usually setup Paperport with the TWAIN driver!
