Taskalfa not booting up
  • brancas
    • Jul 2009
    • 80
    Customer's Taskalfa 400ci not booting up. It is displaying F378 system error and asking to switch off main power.
    Latest firmware V9 was installed. Tried to reset code with MM906 did not work. Tried to format hard drive but because of the system error not formatting. Any suggestions?
  • correo.tony
    • 72
    Put the HDD in another TASKalfa and prove to format it, after put the Fx System out and reload the last firmware version,
    Bye !
      • 23007
      I would try downgrading the firmware to version 5.0. If it helps, I'd replace the CODE DIMM, then upgrade the firmware step by step, all the way to 9.0. Don't skip any of the levels along the way. =^..^=
      • n25an
        • Jul 2008
        • 1030
        i went through that horror today... code dimm... last dimm on the bottom...
        Sad To Say I Don't Have a Life
        I do this stuff on the weekends too
