FSC5650DN ID codes
    FSC5650DN ID codes
    We have a bunch of FSC5350DN that ask for an id code as soon as the menu button is pressed. I have tried the default which is 3000 and that doesn't work.
    I talked to a helpful chap from the Kyocera tech support who emailed me an exe file that resets the printer to default. I linked the laptop to the printer via usb and ran the exe but it didn't work.
    Further email reply's suggested I use the remote interface via a network connection. How can I connect if the printers keypad is locked and therefore cannot find out its IP address?
  • D_Ritter
    • May 2010
    • 16
    Hi Skynet,
    to find out the IP, you can use software like "Angry IP scanner".
    Simply connect the printer to your notebook and start the scanner. It should list you the IPs of all connected devices.
    Good luck!
