Taskalfa colour range general reliability tips and tricks ?
  • cmpelser
    replied
    Re: Taskalfa colour range general reliability tips and tricks ?
    Toners not lasting... Still a problem. Coverage about 5
    Any ideas
    Firmware is on ver 12
  • cmpelser
    replied
    I've now seriosly got problems with toners not lasting, not even close to the yield at all.
    on most of my color taskalfa's
    Please let me know.
  • taskalfaman
    replied
    hi,
    can you tell the toner coverage of this machine?
    I know from expierence that if the machine goes over the 20% toner coverage, the machine goes after approx. 2 A3 R/V prints goes into "adding toner". this is a fact,you can't do a thing about this, the changed some settings to prevent overtoning like in the previous models.
    another topic; if the environment temp is relatively high, this can happen sooner than normal.
    check also all fans and see if the filters are clean!
    have fun
  • knobby
    replied
    I was hoping the new firmware would cure this too, I have two doing the same thing " stop / start 10 prints per minute !
    then eventually locks up
    after reboot it calls for toner
  • cmpelser
    replied
    I'm back at my customer now... and it's saying add tonner A LOT!!! Prints a few pages... adding toner..... prints a few..... adding toner... I've upgraded to the latest ver. 9.something 3 days ago.
    replied
    The TASKalfa does not like to jump from firmware 6.0 or 7.0, to 9.0
    Be sure to upgrade through all the levels as you go or you'll be plagued by cfxxx codes. And yes, I know it takes 45 minutes for each level. =^..^=
  • dickierock
    replied
    sorry to be the bearer of bad news but this issue was brought to my attention after the latest firmware update,the customer said it to me a few weeks later in passing,,i said i'd look into it,havn't really found anything else about it yet..
  • cmpelser
    replied
    Yes that too! As well as what i've mentioned above. Hopefully the new firmware will stop this problem. It's got version 7.something and the new firmware i've downloaded is version 9.something.
  • dickierock
    replied
    definitley go with the firmware,seemed to have cleared up a few issues for me,
    cmpelser,,i had a customer say the machine seems to be saying adding toner quite a lot,does this sound anything like your problem with the toners?
  • cmpelser
    replied
    Any of you guys having toner issues with these machines.
    Where the toner guages "lie" i.e toner guage disappears or it says 50% left but is empty? Or vice versa. Or a new black toner lasts for about 500 copies. This is costing our company a lot of money and is a big problem!
  • knobby
    replied
    Cheers Aragul
    just the kind of post that will make this thread useful
  • aragul
    replied
    There's been a lot of info from the Webinars and Tech Bulletins. Here are some highlights:
    Before doing anything, upgrade the firmware.
    Never unplug or plug in the DP connectors while the machine is on.
    Maintenance modes to run after replacing stuff: (Nov 09)
    Drum - U119, clear U930, U464 AC Calib
    Dev - U464 AC Calib
    Secondary Transfer Roller - clear U127
    Fuser - clear U167
    Basic Image Adjustment - to be done after replacing dev, drum, etc.
    Color Calibration
    Color Registration
    U412 (only if you replace a drum)
    U410
    If you still have color donuts: (Mar 10)
    U140 Dev Roll2 Duty: Change from 373 to 317 for all colors
    Turn the Main Switch Off/On
    U464 AC Calibration Magnification: Change from 0 to ‐5
    U464 AC Calibration: Run Calibration
    Light prints or background issues:
    Undo whatever settings you changed before to try to fix this.
    U325 Set paper interval MODE1(Default) to MODE4.
    U059 Set Fan Mode MODE2(Default) to MODE3.
    DV refresh in the System menu.
    Color Calibration in the System menu.
    U410 Half tone Auto Adjust.
    U464 PrintRate(B/W) 50(Default) to 100. (If printing 85% or greater B/W)
    (Jul 09)
    In U131, if Control exceeds Default by 25, replace dev unit
    Tech Bulletin summaries:
    2 - CIS cable connector protector
    3 - Drawer heater
    4 - Job Separator installation warnings
    5 - Prevent the transfer belt from tearing by moving mylars on the black dev unit
    6 - Motor failure
    7 - Pantone
    Service Bulletin 9053 describes how to clean the LSU cleaner eccentric cams. If they get dirty, you'll hear some funky noise whenever it cleans the LSU glass (at startup or through Adjust/Maint.).
    If you get a bunch of J60s, the duplex switch actuator may be sticking. Try not to have too much fun spending an hour just to get to the switch.
    Always pop out the transfer belt before taking any drum or dev units out.
  • charly
    replied
    many of problem that comment are solved with last update (Firmware Version 09.01.0010),the noises, not of course.
  • Taskalfa colour range general reliability tips and tricks ?
    Thought i'd start a thread re: the genaral reliability of these beasts! ( or the lack of)
    I have 9 of these in my area and 2 trained techs
    the south area has about 15 and NO trained techs
    our machines are no better than theirs so we can count out training.
    Problems range from wandering colour reg, poor density, print driver issues, slow printing, noises, error codes ( not in the manual) mailboxes keep going ofline, invalid user codes ( but they are).
    As much as i am growing to dislike this product i thought it would be nice to have a sort of "positive" thread with tips and tricks to improve all our collective knowledge
    What do you think ?
    Heres hoping
