CS-5050 Scans either terrible in lower res, or WAY to big on 300 DPI
  • tigres
    • Aug 2025
    Is there a firmware update to allow a smaller size save on a PDF on a CS-5050?
    When I scan in a lower res, I get an unreadable document essentially. When I change to a 300 dpi setting, I get a 3.8MB PDF file on 4 pages!!!
    Why on earth is this machine creating such a large file, and why do I need to make the settings as such just to read a scan?
    Please advise, as my 350.00 scansnap makes better quality images at 1/4 the file size.
    Thanks so much in advance.
    • 23010
    You're probably making color scans. Select Monochrome, then see what your file size is. =^..^=
    • tigres
      Nope..
      Tried Monochrome, text, text/photo/ black white.
      Makes no difference, they are huge. Scanning a 120 page pdf turns out to be (on 300 dpi-monochrome) about 24 mb. Obviously, this makes me use other means to break it down, then email it out.
      Thanks for any other tips.
        • 23010
        I have a customer with a Saturn that we did some experimenting to get the best image quality size versus file size. Our settings included Monochrome, Text, 300x300, density +1.
        I don't know why, but scans-to-email produced ~10% smaller file than the exact same settings to a SMB folder. Personally I would have thought that both would be identical.
        I can't imagine why your file size is so large, unless you've got color, OCR, & 600x600 enabled. =^..^=
        • tigres
          I just tested a 4 page legal size scan. Using your settings, (but changed density to +1) I got 317kb
          Why oh why.
          Going to test a big scan next, and check quality. Big thanks for the settings breakdown!!! Also, I am only using SMB-
          Will report back on a big scan. Thanks again.
            • 23010
            Depending on your image fill and background color, you should be seeing, on average, 16.57bits/cm2 or 10Kb letter or 13Kb legal, based on Monochrome, Text, 300x300, density +1. If your pages have very small dense text, or a shaded background, your file size can increase dramatically. Selecting Color scans increases file size by a factor of 10. =^..^=
