Drums whistling, squealing
  • Jimbo1
    • Mar 2008
    • 845
    Has anyone besides me had issues with some of the Falcon I and KM-3035 drums making a whistling, squealing sound shortly after having been replaced? I had this with drums out of two different maintenance kits and wound up having to swap them out. However I got one to stop only after I ran about 25-50 sky shots. Is KM not very good about lubing their drum blades in these units? I have never had to out of the box.
    "Some days you get the bear, some days the bear gets you."
    Cdr. William Riker
  • Lotar
    • 76
    I have had this happen only one time, once i replaced it the issue was gone.
      • 23009
      I have never really trusted the original priming on any manufacturers drum units or blades. Maybe because I started out on Mitas, with Selenium Tellurium drums and separate blades. A blade flip was instantly fatal, so I never take the chance.
      Most moderrn organics and ASi drums are much tougher than those old Selenium Tellurium drums, but I never changed my priming procedure. I've still had a few blade flips over the years, mostly on Sharp Panthers, usually within 1000 prints of installation. The funny thing is that I could never find any specific fault in the priming. I've always used the same Katun drum powder. Drum blade vibration has not been a problem since the Mita DC-211/213/2105/313/313ZD.
      Some Canon drum units used waste toner to damp vibration in the cleaning auger system. After 50 to 100 prints enough waste toner has started down the auger to quiet some squealing or scraping. Maybe it's something like that. =^..^=
      • kyoceradude
        The Great Gazoo
        • Aug 2006
        • 442
        I agree with blackcat4866. Have had to do the same "powdering the blade" with many Fal II drums. (we use Katun powder also) Also performing a drum refresh helps.
        My mission here on Earth is to help all you Dum-Dums!
        • Jimbo1
          • Mar 2008
          • 845
          I was wondering about the drum refresh. Thanks for the help all. These things seem to come and go.
          Cdr. William Riker
          • Jimbo1
            • Mar 2008
            • 845
            Finally just got to where I open the door, put it in 30 and powder the bat snot out of it. That got it. Had a 3050 drum do the same thing so the disease seems to be spreading.
            Cdr. William Riker
              • 23009
              Do you have a lot of bat problems in Oklahoma? Bat snot, bat crap, ...
              • Jimbo1
                • Mar 2008
                • 845
                Nah...I'm just full of bat guano..
                Cdr. William Riker
