keep on adding toner "kyocera 4035"
  • downhiller67
    • May 2010
    • 67
    good day!
    could some one please share on what im going to on my km4035, it keep on adding toner in spite of newly installed toner kit, i made some "130 on service mode" then its ready but after about a 50 copies adding toner is detecting again.
    need your help please.
  • jaime
    • 16
    Good day
    In this photocopier there is in the back part a band that feeds toner and can be damaged
    Probably solve the problem
    • taskalfaman
      • Nov 2009
      • 137
      hi,
      the gear can be damaged which turns the toner.
      but first of all, check if the customer uses the right toner.
      in the past I had several cases, and toner seems the same but was for the printer version or 3050 models.
      • randula7
        • 73
        Originally posted by downhiller67
        good day!
        Check your toner kit.
        is it open well some toners not open well and did you check toner feed solenoid is it working.how about quality of copis.i remember thear is one belt to drive toner kit.its can be damage.open rear cover and see but its dificalt to see because of High-voltage transformer unit and Engine controller
        • downhiller67
          • May 2010
          • 67
          thanks for the reply, i've already check the belt or the band and the gears but they were okey, i tested the solenoids via service mode but for toner it doesnt respond. I'm waiting for my tech to do it today.
          thank you so much for your help, get in touch after my tech do it.
            • 23009
            Like taskalfaman says, check to make sure that the right type of cartridge is installed. Falcon I, Falcon II, and Falcon III toner cartridges all appear to be identical, but have different drive couplers, that means that they won't drive properly in the wrong machine. In the same way Copystar cartridges that look identical, are not interchangeable with Kyocera Mita toner cartridges. =^..^=
            • downhiller67
              • May 2010
              • 67
              problem solved. my tech clean up the toner feed solenoid. and its now okey, thanks for the info guys greatly appreciated.
              more power to all!
