KM-4050 Fax Issues
  • Dave10
    • Jul 2008
    • 197
    KM-4050 Fax Issues
    I have a customer with a km-4050 with a fax system M. I have been out there multiple times for some fax issues and would like to know if others have seen similar problems. First, the customer reports that they are receiving faxes from certain senders which are coming out as a print page and a second page that has no print on it except for 2 asterisks about 1-inch down. I would assume that the sender is sending a long page with these asterisks at the end and its coming out as a second page, but the problem is, when these same faxes are sent to a Samsung machine elsewhere in the office, the second page is not coming out and no asterisks anywhere. Also, they say the system sometimes locks up (I know there is a firmware fix) and that sometimes people get a busy signal all day, but when I go there, no problems. Has anyone had weird fax problems with this system?
    • 23008
    Dave,
    I've had a few fax system M 's that just were not recognized by the machine. Reloading firmware made no difference. I ended up replacing those fax PWB's. Have you done a U600 fax initialize and/or reloading or upgrading the firmware to the current version 2.44? =^..^=
    • Dave10
      • Jul 2008
      • 197
      Thanks for the quick reply. Am going to try firmware tommorrow. Will update.
