Kyocera KM5050 Error CF620
  • wicket
    • May 2010
    • 21
    [Error Code] Kyocera KM5050 Error CF620
    Hi i have a KM5050 with an error CF620, i've been lead to believe it is related to the main controller board. My question is as a result will this need replacing or can i get away with a firmware update???
    Cheers
    • 23007
    cf620 is a print card firmware error. The cause can be more difficult to determine.
    1) There have been firmware levels that have produced CF620 codes. The latest firmware for the Falcon III is v 2.44
    2) When printing duplex jams J00, and cf620 code. Change print emulation from PCL5e to PCL XL
    3) When upgrading barcode font CF card v. 2.00.1A or 2.00.1B to 3.00.0B or 3.01.01B with IC Link utility, cf620 occurs. Use LPR Jar utility to upgrade CF card. IC Link utility does not work well with Wysecore based machines.
    • madas
      • Aug 2008
      • 313
      Hi Ya
      We had a tech with this code on the same model. He told me it was caused by a shorted out N/W cable.
      Something to look at.
      Hope this helps
      Madas
      • wicket
        • May 2010
        • 21
        Thanks for the updates, the problem is related to the network. With the cable disconnected the printer works fine, replaced the cable and updated the firmware to latest level.
        • 1982
          CF620
          Cheers
          Just format the hard disk man, your problem will be sorted.
          update.............
          • wicket
            • May 2010
            • 21
            I did sim u24 as soon as I realised the machine worked ok with the network cable unplugged, but that didn't cure the fault. The fault was the cable
            Thanks again for all your replies
            • kaborwen
              • Feb 2010
              • 146
              Re: Kyocera KM5050 Error CF620
              Hi all,
              I have got this code with KM-2560 but it was an PDF document doing this. I deleted documents on the computer and that's ok.
              • kkendric
                • 301
                Wasn't the last update V 2.45a 08/10?
                  • 23007
                  Sure ... except I posted this 2 months before 08/2010. My psychic powers just weren't working that day. =^..^=
