Kyocera-Mita KM-C2230
+ More Options
Posts
  • tcypy1961
    • 773
    Having copy quality issue with copier. The yellow is bleeding through the other colors using polek test. Copies are being made on 8.5x11R. I noticed the problem on one side of copy only, don't know if it matters on which side but in this incident it is on the side closest to the front of the copier. Copier is saying that it is needing these parts replaced: transfer belt unit, ozone filter, and paper dust remover. Could any of these be causing the problem or is it something else that is causing the problem? Any help appreciated, thank you.
