TASKalfa 400ci " Time for Maintenance T"
  • 1982
    • Aug 2025
    In the operation panel I see "Time for maintenance T" and this machine done 42000 copies.
    After updating the cuurretFirmwar version 9.0, still the problem remains same.
    I have cleraed all the maintenace count. Is anybody faced this similar problem.......
    • 23010
    Where are you tmaged? How did you fix this problem? (We discussed this very thing 3 weeks ago.) =^..^=
    • egpatl
      • Sep 2008
      • 9
      Try doing U906 then inputing the correct date and time. Had to do this today and it worked for me.
      • fourl6
        • Nov 2008
        • 94
        Re: TASKalfa 400ci " Time for Maintenance T"
        That worked, It was a new TA4550ci straight out of the box with C0640 (replaced sata cables) and Time for maintenance (C) on the screen.
        Cheers.
        • Venom
          Technical/IT Support
          • Nov 2009
          • 765
          If you don't set the install date it does that too
          IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
