PC faxing won't, on CS-250ci
    • 22999
    [Misc] PC faxing won't, on CS-250ci
    I couldn't believe it myself. Updating firmware actually fixed something.
    It's a new setup using NW Fax driver latest version 3.5.1405, onto Windows 7 PCs. The driver installs just fine. When you select the print option "NW FX CS-250ci" You get the message "Incompatable printer option" on the PC. You never get the pop-up window to enter your Send information.
    The Fax System (S) was at FAX APL 5PJ_5100.C05.001 (the current version is 5PJ_5100.C05.006 or version 9.01).
    Who would have thought... =^..^=
  • aodtech
    • 194
    Somebody over at Tech Support is celebrating a huge "I TOLD YOU SO!!"
      • 22999
      Humbly, I thought of it myself (as preparation to calling tech support...).
