KM-1820 Kyocera Copier Power Up
  • Bgg
    • Aug 2025
    Hi all,
    Just need some help regarding KM 1820. When power is switched on the display shows the usual KYOCERA name but instead of continuing with the power start up routine, only about three bars are indicated in the display and it stays there and does not continue anymore. I tried power off then on. I tried power up with front door open then close it. All the same, the power up routine does not continue, displays freezes with KYOCERA name and about three bars. Please kindly assist.
    thanks all,
    BGG
    • 23009
    If it isn't completing boot up, I'd start by reloading/upgrading firmware. =^..^=
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
      Paul@justmanuals.com
      • Bgg
        Thanks. I just went through the service manual about upgrading firmware. Where is the firmware available? Is it something I can download from the internet? Kindly advise.
        BGG
        • aodtech
          • 194
          The firmware is only available to authorized Kyocera & Copystar dealers on their website, i.e. not for public download.
            • 30294
            you can try reloading firmware but we had one its the main pcb failure
            • lvsb
              • Aug 2008
              • 70
              I agree with bsm2 mainboard. We had this issue a few times.
              • ewa
                ewa
                guys please help me with code c6000 which appear on display board. thanks
                  • 30294
                  reset fuser code in service mode 163
                  • ewa
                    Please , if you can tell me step by step . Thank you
                      • 30294
                      Turn off machine, open top cover,then turn back on ,Press 'system menu/counter' key, select 'service setting', then while pressing 'start' and '#', press 'enter'. Select 'Maintenance mode', then press 'enter'. Enter '163' using the up/down keys, then press 'enter'. Turn machine off to exit Maintenance mode.
                      • ewa
                        Thank you very, very much. It's working.
                        • happicopy
                          • 51
                          best thing to do is try to look for some previous thread in this forum, resetting those codes have been discuss previously.....try advance search option....type km 1820
                          • Frits
                            • Jun 2009
                            • 62
                            service mode
                            ewa Here how to get into service mode
