km4850w
  • ktech
    km4850w
    cant print to the 4850w. the online light keeps flashing but wont go online.
    also if I remove the autocad controller is it possible to still make copies.I have tried to remove the controller but when I go to copy the machines reads memory full.
  • bignitz
    km4850w
    I think controller harddisk had failed. try reformating hdd.
    • ktech
      How do you format the hdd is this done through the control panel inservice mode
        • 30210
        order new hdd kyocera
        • Ducttape n Glue
          • 195
          Yank the HDD and buy it locally, cheaper than KM, thats what we did
          • Ducttape n Glue
            • 195
            We did this with the 2nd version Cadmaster controller. There were several versions of the Cadmaster controller and also a Ratio controller. I think the original cads used AMD and the 2nd versions used Celeron, I have never seen a Ratio. I also read somewhere, maybe here, that Ratio filed for bankrupcy.
            • Hutcheson
              • 15
              I would also pull the processor from the cad controller and clean off the heat sink compound and use fresh compound on it.
