kyocera km 4035 "0630"
  • downhiller67
    • May 2010
    • 67
    good day!
    i have kyocera 4035, i ran few copies today but the result was very dark "looks like ink spell on the paper" then appears the " system error, turn off main switch" then 0630.
    need advice on what is the problem with this machine. just an end user.
    thank you so much..
    • 23008
    The C0630 means that the ORGVSYNC signal (the document processor original scanning interval signal) is lost.
    My best advice is to call an experienced service technician, to investigate the possibility of a damaged cable from the document processor to the MFP. =^..^=
    • Jimbo1
      • Mar 2008
      • 845
      I have seen that be everything from the df cable to the contacts on the transfer roller to the scanner card.
      "Some days you get the bear, some days the bear gets you."
      Cdr. William Riker
      • downhiller67
        • May 2010
        • 67
        thank you for the replies.
        it not C0630, its just plain 063 with no C, anyway the problem solved, i just clean the part that has corona wires on it, a lot of toners on it.
        thank you and more power!
