Km 5050/ false jam from sleep mode
  • tech07
    • Aug 2008
    • 409
    [Error Code] Km 5050/ false jam from sleep mode
    Here's a good one..Kicking my ***...KM5050 runs fine all day no jamming or quality issues...HOWEVER, customer goes home at end of day, copier goes into energy save sleep after 4 hours...customer comes in next morning, pushes power on to wake copier up and it gives a Jam 80...(jam in finisher)..opening and closing any finisher door resets and all is well, all day. until next morning. same thing every morning.Updated firmware, cleaned sensors and verified operation through test mode...False jam only when coming out of sleep mode..Help?..
    • 23008
    Originally posted by tech07
    ... Updated firmware, ...
    But to what level? This was supposed to be fixed in v. 2.20C, which was Sept 2008.
    Currently it's 2.44 04-27-10. =^..^=
    • tech07
      • Aug 2008
      • 409
      It's @ version 2.44 definately..flashed it twice.. tech support wants me to check wall outlet.. Since it runs well all day, I have to rule out bad sensors, connectors, etc. because it would probably occur at least once or twice . I'm going to set sleep mode to 1 minute and try to see it myself..maybe even disconnect finisher to see what happens since Jam 80 is a finisher code
      • Jimbo1
        • Mar 2008
        • 845
        This is a real leap but you know some of these finishers do squirrely things because the connector inside the connector to the copier works it's way loose. Check it just to be sure.
        "Some days you get the bear, some days the bear gets you."
        Cdr. William Riker
        • LNorris
          • Sep 2008
          • 645
          can you duplicate it? put the machine to sleep and wait. do it in 15 minute intervals to see if you can duplicate it.
          i second Jimbo's response. detach the finisher and see if it continues as well.
          • Dave10
            • Jul 2008
            • 197
            Machine was an Konica but the exact same problem. Only gave the jam code when coming out of sleep. It was a dirty paper sensor. Cleaned all the sensors and problem solved.
            • tech07
              • Aug 2008
              • 409
              Still fighting this....Does not occur if finisher is removed..
                • 23008
                DF-710 or DF-730?
                • tech07
                  • Aug 2008
                  • 409
                  DF-710.....
                  • aodtech
                    • 194
                    You must be getting a different jam code now if the finisher is unplugged. Check the exit unit and clean the paper path solenoid, the one that determines paper output. It sticks sometimes and if it's just sitting there... there could just be that little bit of gunk there that's screwing up paper timing.
                    • tech07
                      • Aug 2008
                      • 409
                      there are no jams when the finisher is unplugged. I set the sleep timer at 2 minutes with the finisher attached and got the J 80 the first copy every time. There is no paper..false jam..
                      It displays copying for 4 or 5 seconds then jam 80...After unplugging the finisher and testing there were no more jams. Keep in mind that it only occurs with finisher aattached and when coming out of sleep mode..I replaced the finisher entry sensor for nothing. What is making this difficult is after clearing fa;se jam once in the morning, it doesn't happen the rest of the day. This makes me think sensors are ok..I getting reafy to cut tie wraps and may replace finisher pcb.
                      • Jimbo1
                        • Mar 2008
                        • 845
                        Have you taken that connector apart and looked to see if any of the connectors inside are backed out? I have seen lots of those and they cause squirrely issues.
                        Cdr. William Riker
                        • dhenderson
                          Had same issue on a CS-5050 and DF-710. Repalcing the finisher main PWB solved the issue. Hope this helps.
                          • flimmer
                            • Jun 2008
                            • 30
                            Have seen that the harnes to exitsensor main tray of finisher may be partly broken and the sensor itself has been periodicly bad.
                            • tech07
                              • Aug 2008
                              • 409
                              All make suggestions make sense, however, please see my earlier post. This Jam 80 ONLY occurs if comming out of energysave/sleep mode or the 1st copy after being turned off and back on. During the day, the customer has no problems. Their morning routine is to open the office, make coffee, bring copier out of sleep mode, run one copy, clear false jam by opening and closing finisher door and then there are are no more problems the rest of the day.
