Hi all, have a customer with a KM 2050, up untill two weeks ago when they replaced thier server incoming and outgoing faxes would be forwarded to the scanner file utility to be stored on the server.
My problem at the minute is that outgoing faxes are stored, incoming however are not. The machine is set up properly but it has me buggered why it would send data for transmitted faxes but not for recieved ones.
The server is nothing special, basic small office server.
The fax defaults are set to print locally and forward the fax.
Scanner File Utility is the latest version.
Fax Address Editor settings are correct.
Firmware is up to date.
Kyocera have no more answers for me.
So I put it out to you guys, hoping that someone has seen something like this before.
Cheers.
Cheers.
