Firmware Upgrades
  • daveyball
    • May 2009
    • 314
    Firmware Upgrades
    Hi All
    Is there any particular make or size of USB stick that is best to upgrade the firmware with. Sone of ours will some won't, even the Kyocera one's given to us by Kyocera UK, are bit on and off. Or is there something you need to do to the stick before loading the firmware?
    Cheers
  • JSC
    Gimp
    • Dec 2006
    • 618
    Keep the size down to 2gb or less although I have seen up to 4gb work, I use Kingston without any problem. We had some free sticks from Kyocera Uk that lasted all of 5min, I suppose thats why they were free.
    The gene pool could use a little chlorine.
    • daveyball
      • May 2009
      • 314
      Cheers for that, I used an old Kingston one yesterday, that was about 2Gb, and that worked OK. You're probably right, you dont't get owt for nowt (Northern English for "sod all" for our US friends) these days
        • 23010
        On the ones that still take compact flash, I use that. The TASKalfa and CS-420i take USB, and yes, 2GB or less works best. The current firmware is only 112MB. Why would you need more capacity?
        • madas
          • Aug 2008
          • 313
          The only thing i do is format on the PC in "FAT" before copying the files over, not had a problem so far using a 1gb stick.
          I also use CF card where possible.
          madas
          • aodtech
            • 194
            I have only used Sandisk and have had no problems at all. I normally use a 4GB for firmware updates. The only thing is that you have to remove the U3 software partition or else it won't be recognized.
              • 30563
              128mb to 512mb work great you can also use the same on a CF card
