CS-5050 code CFB31
  • DAVEC
    • Jun 2025
    CS-5050 code CFB31
    Anyone ever have this code and how do I fix it????
  • madas
    • Aug 2008
    • 313
    Hi, nearest i got is
    Blue back screen, cannot get in to maintenance mode.
    possible problem with the panel PCB controller.
    hope it helps
    madas
    • taskalfaman
      • Nov 2009
      • 137
      HI, the SM tells;The rejection of communication by controller during start up possible cause Blue back display.
      (possibility: defection of Panel board, controller board, connection cable, etc,...
      was it a a white or grey background on the display?
      did you upgrade with cf with door open; if Yes= > did the machine displayed every part of F/W ok or NOT FOUND.
      my solution => HDD externally format, reload FW problem should be solved.
      second solution= > did you took aout the display? => wrong cable in wrong connector in display pcb (One cable can go in to connectors)!!
      please feedback!
      • Frits
        • Jun 2009
        • 62
        List of CF code's
        CFB30, CFB31, CFB32 = Communication error between Main PCB and Panel PCB.
        upgrade the firmware. There was a case of defective Main Memory DIMM (SDRAM), so this might also be a
        possible cause.
        MEASURES:
        - Check the contact between panel DIMM / socket. (Reseat DIMM)
        - Upgrade the firmware or replace Panel DIMM. (Be sure to check FW combinations)
        - Upgrade the firmware or replace Main DIMM. (Be sure to check FW combinations)
        - Replace Main Memory DIMM (SDRAM).
          • 22999
          This error may show up when there is poor contact between the Panel DIMM and it’s socket, or failing to
          possible cause.
          MEASURES:
          I second... =^..^=
