LPR Jar utility
  • jewen25
    • Mar 2009
    • 197
    LPR Jar utility
    can i i use LPR Jar utility to update frimware?
    ERROR HELP ME AND HELP YOU
    • 22999
    No. Depending on the model of MFP you'll use either a compact flash card or a USB memory stick. =^..^=
    • jewen25
      • Mar 2009
      • 197
      km-1820 jar utility well work?
        • 22999
        Still, no. You'll use a CF card. No utility required in this case.
        • jewen25
          • Mar 2009
          • 197
          thanks but what particullar CF i well use and,where i put the CF card i have,or i well use adapter of CF card? pls help me step by step to do
          • n25an
            • Jul 2008
            • 1030
            make sure its about a 128k compact flash card...
            install the firmware on the card...
            make sure the take off the right cover of the copier...
            turn off and plug out the copier...
            seat the card in the board
            then follow the steps in your manual
            Sad To Say I Don't Have a Life
            I do this stuff on the weekends too
