how to use prescribe command?
  • jewen25
    • Mar 2009
    • 194
    how to use prescribe command using LPR Jar utility? pls help me
    ERROR HELP ME AND HELP YOU
  • aabarnes1
    • Mar 2009
    • 620
    Jar utility ??
    Grant me the serenity to accept the things I cannot change.
      • 22929
      So what is the problem? Have you downloaded the utility? Have you composed the command? Have you written the command into a Notepad file? =^..^=
      • jewen25
        • Mar 2009
        • 194
        i wANT TO LEARN THIS prescribe command pls help me what to do?
          • 22929
          What PreScribe command would you like to execute? =^..^=
          • jewen25
            • Mar 2009
            • 194
            reset password of because my customer for got the password of the km-2810
              • 22929
              You have two possible choices for the command:
              !R! ACNT "REST";EXIT;
              to reset the admin password, or
              !R! EGRE;EXIT;
              to reset the engine (everything).
              Download the LPR Jar utility to your PC.
              Network your PC to the desired printer via crossover cable.
              Write the desired command inside a Notepad or Wordpad file, name it, and save it.
              Double-click the utility to open it.
              Enter the IP address of the recipient printer.
              Browse to the Notepad file with the command.
              "Send"
              The utility will run from a USB stick. If you have access to a PC that is already networked to the printer, you can just insert the USB stick and run the utility. Some of my larger customers have Java commands blocked across the network. In this case I have to connect directly via crossover cable to my PC. =^..^=
              • jewen25
                • Mar 2009
                • 194
                [QUOTE=blackcat4866;159764]You have two possible choices for the command:
                !R! EGRE;EXIT;
                "Send"
                The utility will run from a USB stick. If you have access to a PC that is already networked to the printer, you can just insert the USB stick and run the utility. Some of my larger customers have Java commands blocked across the network. In this case I have to connect directly via crossover cable to my PC. =^..^=[/QU
                "i use XP1 windows operating system i not familliar with JAva,what requirments to run the LPr Utility?
                  • 22929
                  It will run on Windows OS XP/Vista/7. =^..^=
                  • JustManuals
                    • Jan 2006
                    • 9838
                    Better idea, RTFM!
                    • RRodgers
                      • Jun 2009
                      • 1947
                      Originally posted by manuals4you
                      Better idea, RTFM!
                      LOL
                      And he if doesn't have one... I'm sure you'll hook him up. ( for a fee of course!!! )
                      • JustManuals
                        • Jan 2006
                        • 9838
                        Of course. Business is business. And it IS my business
                          • 22929
                          Please guys, can you feud on some other thread?
                          Jewen: I can't do this for you. Eventually you will have to try something. So do something, then post back. =^..^=
                          • Eric1968
                            • 2458
                            Better idea, RTFM!
                            Even more better idea :
                            Stop posting these annoying RTFM-postings. The guy is just asking for some help!
                            • jewen25
                              • Mar 2009
                              • 194
                              ok blackcat i well do
