List of CF code i know maby this will add something
  • Frits
    • Jun 2009
    • 62
    • 23009
    This is great Frits! I'll roll it into my reference.
    Is this list specific to a particular model? =^..^=
    • Frits
      • Jun 2009
      • 62
      Wiscore general, i also have a list voor the Falcon 3 stratos models if it's off any use for you
        • 23009
        I think I already have that list, but would like a look please. =^..^=
        • Frits
          • Jun 2009
          • 62
          Here's the link to download my file http://www.hcsm.nl/CF.xls
            • 23009
            This is the same list, just Excel format instead of PDF.
            Since the Falcon III and Stratos are both also Wysecore machines, it only makes sense that the list would be the same.
            Thanks again. This fills in a lot of gaps in my reference. =^..^=
            • LNorris
              • Sep 2008
              • 645
              anyone know what a f246 refers to? its on a ta500ci
                • 23009
                "CF246 Process Manager: SYS_PRCM_ERR_FACTOR_DEV_PRC_DOWN (Device process down)" Upgrade firmware above v. 3.06.
                I sure hope your running something closer 9.01. Other codes in this range are print driver and print emulation related. I think I'd get that firmware to 9.01, get the driver up to v. 5.1.1405, then if you're still having trouble try some of your emulation options. =^..^=
                • Eric1968
                  • 2458
                  Thanks, I was searching for this document for some time.
                  • LNorris
                    • Sep 2008
                    • 645
                    yeah, i'm running 9.01 on it. i got on site and it had flipped a c0640 code. i reflashed firmware, upon restart the f246 came back. got into mm and ran 917 and 021. system came up. i ran 917 to put address book back on, the f246 came back. powered off/on, on restart got a f375 (which i cant find either). powered off again, hung up in restart screen. tech support said to remove fax and reflash. removed fax and reflashed, got the c0640 code again, ran 024 per sm. system came up. re-entered ip address, restarted and system hung up. thats where i left it yesterday afternoon. any ideas?
                      • 23009
                      Replace CODE DIMM or Main PWB, then flash.
                      I can't help you with the CF375. I don't even have a reasonable guess. =^..^=
