Kyocera-Mita KM4030
  • tcypy1961
    • 773
    Kyocera-Mita KM4030
    Our customer can print to the copier and when they were doing so they were trying to duplex. However they can not click on the duplex option. What do we have to do to get the duplex option to show up in the print preferences? Yes the machine can duplex. Any help appreciated, thank you.
  • aragul
    • Dec 2007
    • 128
    Control Panel -> Printers -> Right click on 4030 -> Properties -> Device Settings tab -> check Duplex. This is for the KX driver; the KPDL and PCL uni drivers are different.
      • 23008
      You need to configure the driver, so that all the options are available to you. aragul is right, of course. =^..^=
      • Hemlock
        • 432
        Isn't there an auto config check box under properties that polls the machine in order to populate the options within the driver?
        “Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'” (Isaac Asimov)
          • 23008
          Yes, on the newer versions of the KX driver. There have been quite a few driver updates since the Falcon I came out. It could be a very old driver or a universal driver lacking that function. =^..^=
