Trying to print to a TASKalpha 500ci using job accounting on a MAC 10.6. To turn on you have to go into the app and check the box and put a code in but the box has a line through it. Unable to print with job accounting.
Job Accounting From MAC 10.6
We have seen this in the driver for Fiery Controllers. If you ar printing from a 64bit application, try to open it in 32 bit mode and print.
Apple - Support - Discussions - OSX 10.6.2 Network Printing Issues - ... -
Account Codes with MAC
After you have installed the printer on the MAC
Open any document to print
Select the Kyocera
Click on the arrow to the right of where it shows Copies & Pages
Select Job Accounting
Check the Job Accounting box
Enter the Account code
You can check lock these settings if they never use a different code.
