I'm not an official technician, but I'm appointed by my company to try and fix any printer that is out of service contract because of too many pages printed.
So I got a FS-1800 which printed very dirty pages, with vertical stripes. I found out that the channel inside the drum, that carries the waste toner away from the drum and into the waste toner bottle, was totally stuck with dirt. So, the whole drum was full of waste toner, and the waste toner was forced out on the drum, causing the stripes.
I removed the drum roll from the drum holder, and then took the drum holder outside and cleaned it with compressed air. I assembled everything back together, but now when I switch on the printer, I get the Dutch message that is equivalent to "check waste toner bottle" on the display. Needless to say, the toner bottle is clean.
I don't see any sensor of any kind. What exactly triggers this error?
Also, once this problem would be fixed, do I need to select in the menu that I replaced the drum, as the whole drum is now empty of any (used) toner? (Right now I don't even get the chance to enter the menu.)
Thanks in advance!
Thanks in advance!
