Kyocera service bullitens
  • tech07
    • Aug 2008
    • 410
    [Misc] Kyocera service bullitens
    Is there a good way to search Kyocera website for specific service bullitens? For example I was looking for a bulliten about a PF750. I used the bulliten page, the Q A page, the helpdesk page all for naught..Then by chance I saw one here on this forum . It was called SB-8543. How do you find these on their website..??? Can you search by SB per model??
    • 23010
    You'll usually get the best results if you search the desired model in QA. =^..^=
    • just a tech
      • Jan 2007
      • 332
      sometimes it's also a play on words type thing. depending on what "keyword" you use depends on how many hits you get within the knowledgebase area. For example: if you had an error of C6050, you may get different amounts of hits depending on if you used keyword C6050, C-6050, C 6050. Same with jam codes for the keywords: J53, J 53, J-53. Therefore, sometimes try different versions of keywords and you'll have more results. Good Luck.
      • DWise
        • 895
        PF750 comes up as a selection under the Bulletin section with "Accessories | Paper Handling" menu selected.... but there's no document listed to click on...
        Do for one what you wished you could do for everyone. - Andy Stanley
        • kkendric
          • 301
          kkendric
          Go to Tech Resources, Help Desk, Search Q & A Database, Type in search bar PF-750 do not forget the dash. This should pull up all kinds of service bulletins.
          • kkko
            thank you very much
