Scan to Email
  • shep
    • Sep 2010
    • 108
    [Misc] Scan to Email
    In a windows 7 environment, 300ci, using godaddy.com email server. it does require authentication, i keep getting 1102 code saying name and password are invalid, had godaddy on the phone and the login name and password are correct but i still keep getting a code, any ideas??? it will connect without authentication with the test button but from the machine to go it needs authentication............
  • spandx17
    • Mar 2010
    • 30
    What SMTP port did they say to use? If it is 585 your are pretty much SOL!! Most companies like godaddy and Google's GMAIL use TLS encryption for authentication. According to Kyocera,TLS is not supported only SSL. I would suggest you use an open SMTP if their ISP allows access or use an SMTP provided by their ISP.
    • mike*
      • Jun 2010
      • 58
      is the server smtp.secureserver.net? the only port thats open on that server is 25...
      ive had sucess with smtp.secureserver.net (i think godaddys smtp server)
      port 25
      user name - user@domain.com
      password - whateverpasswordis
      and for some reason i think i remember trying this server with ssl enabled and tried port 465, 587 and then 25 and if finally worked on port 25 with ssl enabled? weird but it worked for me
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1867
        GoDaddy
        In your SnapperMail server account settings (Menu -> Accounts -> Edit Accounts -> (choose account) -> Server), enter the following:
        • POP3 Server: mail.godaddy.com
          Username: your entire GoDaddy Email address (i.e. username@godaddy.com or yourname@yourdomain.com)
          Password: your GoDaddy password
          On the "More?" screen, leave all the checkboxes unchecked (all SnapperMail editions) and select "No SSL security" (Premier/Enterprise editions).
        • SMTP Server: smtpout.secureserver.net
          On the "More?" screen, leave all the checkboxes unchecked (all SnapperMail editions) and select "No SSL security" (Premier/Enterprise editions). If you have trouble using the SMTP server, try setting the port number to 3535 on the "More?" screen.
        If you have difficulty setting up and/or using the GoDaddy SMTP server (i.e. you get a "501 Authentication failed" message), you may have to set up the relay configuration in your GoDaddy account. The following links provide information on what the relay is and how to set it up:
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
          • 29792
          try the port change 3535 also check with the IT guy and make sure they are not blocking port 25
          • colin
            IT
            • Sep 2010
            • 38
            If your getting an "OK" using just the server settings you know those work. 1102 is an authentication error. I would definitely try using an ssl protocol and try changing the port to 465. I bet godaddy requires a secure connection. Let us know how this turns out.
            • johnschijndel
              try to use the ip-adres from te mail server instead of the servername
              you can get the adres by pinging the servername it wil reply with its ip-adres
