Cant access advanced tap in command center
+ More Options
Posts
  • shep
    • Sep 2010
    • 108
    [Misc] Cant access advanced tap in command center
    Just what the title says, its really weird, its on a 420i from the computers we can enter the command center just fine but the advanced tab comes up completely blank(white page) luckily i was able to get into the advanced tab by using the web browser on the machine so its all set up, just wondering if anyone has seen this and what may cause it.
    • 30475
    what web browser IE , firefox or other?
      • 23010
      Ooohh! Good suggestion. Many of the older Kyocera web pages do not work properly with Firefox. IE only. =^..^=
      • shep
        • Sep 2010
        • 108
        It was with IE, not sure that it would matter because every other page in the command center would open and could be changed just fine, only the advanced tap would not load up.
        • aragul
          • Dec 2007
          • 128
          I've only had Firefox issues with the NS-30.
          I think I've seen this before, but I don't remember what fixed it. I'd try redoing firmware and maybe format the hard drive U024.
          • shep
            • Sep 2010
            • 108
            alright thanks, firmware was reloaded at the time but we did not reformat the hard drive.
            • JSC
              Gimp
              • Dec 2006
              • 618
              Had this a few times with people running the full internet security package of Kaspersky, its strange it only blocks the advanced tab, the anti viris only version is fine.
              Hope this helps
              The gene pool could use a little chlorine.
              • shep
                • Sep 2010
                • 108
                thanks at least that gives me an idea of what it was, it just seamed really strange...
                • Heleric
                  • Oct 2010
                  • 8
                  Also try giong to the Security Tab and under Internet Options add the IP as a Trusted web site. Remember to remove the check mark for https.
                  • mike*
                    • Jun 2010
                    • 58
                    ive had the same issues with konica machines and IE8. Certain tabs wouldnt load and others would just lock up the browser. Always use firefox or opera now and alls well
