drum moisture
  • gansathya
    • Jul 2010
    • 45
    drum moisture
    hi friends,
    kyocera km 5035 model have a drum moisture problem, every day morning we need to do drum refresh near about 4 or 5 times after only copier is ready to copy, otherwise copies come background what we need to do?
  • Jules Winfield
    • Jul 2009
    • 821
    If you are experiencing condensation on the drum every morning, then you might want to consider keeping the copier in a climate controlled room. Or maybe just put a space heater near the machine when the weather is cold. By the way, don't put the space heater on the same circuit as the copier.
    But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
      • 23009
      I don't know if they're still available, but you might seek out the drawer heater option.
      • madas
        • Aug 2008
        • 313
        Hi,
        I seem to remember we had a couple of these with condensation in the morning but if I remember right it was built up on the side door guide fins and left streaks across the first few prints.
        we told the customer to wake the m/c up when they arrived at the office and let it sit for 10 mins or so before using it. may be a option to try or as Blackcat says buy a heater.
        madas
        • dunnbiz
          • Mar 2011
          • 13
          drum moisture
          I have seen condensation on optics when environment becomes supercooled in A.M. when the AC is turned on, when Humidity is high; but not on drum. But room environment has to be adjusted. I don't know if the draw warmers would solve this . Machine is supposed to be kept in stable temp/humid. environment to function properly
          • Venom
            Technical/IT Support
            • Nov 2009
            • 765
            Try replacing Drum and see if it makes a difference
            IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
            • DWise
              • 895
              I'm interested to know what the "fix" was... I'm guessing it was in a non-climate controlled environment.
              Do for one what you wished you could do for everyone. - Andy Stanley
