Kyocera Fs-1118 startup error
  • haldur
    • Jun 2009
    • 37
    hi guys
    machine freezes at startup while loading and is unable to use
    what can i do to fix it?
  • Warstg_20
    • Sep 2009
    • 72
    try to load latest firmware
    hope this helps
    • jackh
      Originally posted by haldur
      hi guys
      If you panel is locked on Kyocera with a several bars (similar to normal warmup), then unfortunately it is an Engine PCB with the possibility it has taken out the main PCB. Do not replace the main PCB, thinking this is the issue as the faulty Engine PCB could take that one out.http://www.copytechnet.com/forums/im...cons/icon6.gif
      • finni72
        • Jul 2010
        • 25
        I had a simular problem with a Olivetti d-copia 18MF.
        I tried to change all cards on the machine with an used machine i've had extra ,but it didn't work. In the en i had to use the old machine.
        The only electrical part i didn't change was the scanner.
        Can the scanner be the issue?
        • Jeandre
          Re: Kyocera Fs-1118 startup error
          Hello there had more than one machine with same problem, just remove fax kit and problem solved (Faulty Fax Unit)
