taskalpha 420i numeric keypad problem in copy mode
  • jrs157
    • Jul 2010
    • 22
    New install,flashed machine to latest firmware,swap out control panel,reseated every connector in machine, simm mode U906 reboot.
    Still have problem with selecting buttones. In fax mode and scan mode, keypad functions as advetised.
    I will swap out boards next Monday morning.
    Anybody have this issue in the copy mode option only?
    AN ounce of prevention is worth a pound of obscure
    spare screws
    • 22996
    Nope. I've never seen a panel issue affecting only one function.
    You've tried all the things I would have. Maybe you might downgrade the firmware a step or two, just to see if it changes anything. =^..^=
    • peterepeat
      • 84
      When you upgrade/downgrade the firmware be sure to check the result on the screen for each of the individual files.
      Only other thoughts would be
      U201: Initialize Touchpad
      U207: Panel Key Check
      U021: Memory Initialization
      Sounds like a Main board though.
      • jrs157
        • Jul 2010
        • 22
        I did the U201 , doubt the 021 will fix it and didn't consider the 207,
        but I'll swap out the main PWB and warranty the item
        spare screws
