utax cd 1120 error (c6050)
  • gregoryk
    • Jul 2025
    Hi! can someone sent me the procedure to reset the (c6050) code please?
    I'm not familiar with utax machines and i dont know how to do it
    Thanks in advance!
  • aragul
    • Dec 2007
    • 128
    The fuser reset is the same as most Kyoceras: enter 10871087 to get into maintenance mode; then run sim U163.
    C6050 is "Abnormally low fixing unit thermistor temperature"
    • gregoryk
      thank''s for the replay aragul but can you tell me how exactly to get in to the maintenance mode? just strike the code?As i mention above i'm not familiar with that branch of the machines.I mostly work with "xerox" machines.
      • aragul
        • Dec 2007
        • 128
        Yeah, just type the code in. It should work when the machine shows the c6050 error.
        • gregoryk
          ok! thank you i'll give a try!
