CS-4035 C0610
  • alpha-omega tech
    • 80
    CS-4035 C0610
    I have a CS-3035 giving me a C0610. Everytime I reseat the dimm it resets the error and I can copy and print. This dimm is on the main board. If I power down the copier and turn back on I get the C0610 code again. I am hoping the problem is just the dimm and not the main pcb. I also updated the firmware. Has anybody had this issue before, and also can I get a dimm from a cheaper source or do I have to use a dimm from Kyocera for the main board dimm.
  • JustManuals
    • Jan 2006
    • 9838
    ]This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
    Paul@justmanuals.com
    • alpha-omega tech
      • 80
      I have manuals.
        • 22929
        The DIMM is the most likely cause.
        As a rule I don't have any problem with using the generic memory. I haven't had any problems specific to generic memory. But the machine probably won't boot or update firmware without some sort of engine firmware on the DIMM, so I don't think you'll be able to use the generic DIMM in this specific case. =^..^=
