FS-2020D Error Code F615
+ More Options
Posts
  • HenryT2
    • 962
    We had a FS-2020D come in for repair. Original problem was constant jams. Found the cause of jams was a small piece of paper wedged in the 'guide, feed up ' in the duplexer.
    When cleared and could run an event log, I found several 6400 error codes at approximately 2K intervals. Then while running test prints, I got a " ERROR - POWER OFF F615 " error code. I could not find this code listed in the manual. After I power-cycled the printer and ran another event log: I found the following shown; F615 ; F46F ; and 6400 ; all at the same page count. Have any of you great techs had anything like this before, or any info on these codes?
    I will update the firmware and run more test prints, and see if this helps.
    Any input will be appreciated.
    "The Serenity Prayer" . . .
    God grant me the serenity to accept stupid people , the courage to not waste my time and energy on them , and the wisdom to know that I cannot fix STUPID .
    • 22997
    You won't find it in any manual.
    cf615: Report Page Generator: USV_RPG_ERR_FACTOR_STREAM (Stream access error). Re-load firmware.
    cf46F: PDL Interpreter: REN_INT_ERR_FACTOR_GENERAL (other general error). Re-load firmware.
    I think its a consensus. Re-load firmware. =^..^=
    • DWise
      • 895
      Just curious, how did you come across it if it's not in a manual?
      Do for one what you wished you could do for everyone. - Andy Stanley
        • 22997
        I'm a member of a Kyocera only forum, and the subject of the "secret" cf codes has been a frequent topic of discussion. Why the hell would an MFP manufacturer have certain "engineering" error codes, then not tell anybody what they mean? =^..^=
        • HenryT2
          • 962
          Just an up-date........After up-dating firmware, I ran about 300 sheets duplex and about 200 from cassette with no errors. Thanks for the input Blackcat.
