CS-3035
  • TONERINMYNOSE
    • Aug 2010
    • 114
    CS-3035
    Is there a way to reset the total count? I just rebuilt one of these for a customer (sold it as a rebuild) and would really like a zero meter if possible.
  • Jules Winfield
    • Jul 2009
    • 821
    Even if the customer is aware it's a refurb, it's still illegal to reset the meter to zero. It would be the equivalent of zeroing out the odometer of a used car you're selling. Plus it will throw all the maintenance intervals off. There is no good reason to zero out a meter unless you are trying to deceive someone.
    But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
    • MadCityCopy
      ieeeee
      • Oct 2010
      • 58
      As stated you should not under and circumstances zero out any machine. Its just terrible business. If you have to tell a customer this is a brand new machine when its obviously an old rebuild you need to re-evaluate your business practices.
      • TONERINMYNOSE
        • Aug 2010
        • 114
        look guys this is what my boss asked me to do, the customer is aware it is rebuilt, please dont crucify me.
          • 23009
          If you've been around here any length of time, you'll know this is not a valued business practice. Just say it can't be done. Moraly or Ethically. =^..^=
          • pjdbm
            • Sep 2007
            • 360
            Tell your boss that no matter what this is not an ethical thing to do, Tell him that I am an Independent and sell these used overhauled all the time and I leave the meter alone. Once overhauled the meter means nothing. If the customer wants a off leased LOW meter than he will have to pay more.
            • Venom
              Technical/IT Support
              • Nov 2009
              • 765
              Just play stupid...works for me...lol
              IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
              • galumina
                • Sep 2010
                • 32
                Don't do it you can get into big trouble and go to jail for this it happened to an old friend he went to federal prison for 5 years. Just tell your boss that if someone tells on you the FBI will be at your door and your bosses. I am not kidding saw this first hand.
                • gmckenna
                  • Dec 2010
                  • 11
                  This is an interesting discussion. I recently purchased 4 used FalconII series from a wholesaler. They were listed as low meter (40k to 60K). The total meters were low, but I had DV counts all over the place. 3 of these had the exact same count (over 4 mil)in the drum history.
                  • gmckenna
                    • Dec 2010
                    • 11
                    One of these machines came back to my shop for not adding toner.After more than a day of tearing it down and replacing EVERYTHING in the toner adding circuits and mechanics, it turns out that the EEProms were causing the problem. I really wonder if someone was hacking in there.
