cs2050 fax "register" button just beeps?
  • brianhj
    • Jun 2025
    The user guide says to press the "register" button while in fax mode to set up the fax header information. However, when I press register, no menu appears on the lcd, the copier just beeps. Any ideas? I contacted cs support but they were no help. I updated the fax firmware. Faxing otherwise works, both ways.
    • 22999
    Try a U600 fax initialize, then try again. =^..^=
    • brianhj
      Already tried 600 and 601 to no avail
      • monstott2010
        Is the "door/flap" activating the switch correctly? I have seen them broken or dislodged so that the switch is not activated and the panel is confused on what functions you are trying to use.... just a thought
