Kyocera KM 3060 can't connect to network now changed network card settings
  • goose1127
    [Misc] Kyocera KM 3060 can't connect to network now changed network card settings
    I was in the command center on a Kyocera 3060 and inadvertntly changed the 10/100 auto connections from auto to 10baseTfull now I can't get in to the printer through the web command cernter to change it back and can't find that setting in the control panel on the printer. anyone know where to find that?
    • 23010
    An engine reset should do the trick. Send this PreScribe command:
    !R! EGRE;EXIT;
    • goose1127
      I found the answer I used the 1087 and 021 command and reinitiated the memory. That set it back to factory defaults andit's great now.
      Thanks for the reply...
