how to set up fax in kyocera mita km 3035
  • dipakpatel
    • Sep 2010
    • 34
    Help needed..how to set up fax in kyocera mita km 3035..
    • 22997
    Are you installing the fax option in a machine that has never had it? Read the instructions included in the box. Then flash the machine when you're done with the instructions. =^..^=
    • dipakpatel
      • Sep 2010
      • 34
      fax card is there..i need how to configure it in km 3035
      thank you for taking your valuable time to help me.i have fax card,the only thing i need to know is how to configure or what configuration are needed to start making fax working..
      thanks again
        • 22997
        Just the basics:
        Set the time
        Enter your name and phone number
        Plug the phone cord into the "Line" port, not the handset port.
        You can program some speed dials if you like.
        Is it a fax system (F) of fax system (J)?
        • dipakpatel
          • Sep 2010
          • 34
          Thank you:i will check for fax f or j
          i am thankfull to you..i will check for j of f fax system..
          thank you.
          • lsaunders
            fax j installation procedure on mita km-3035
            I'm about to install a Fax J into a Mita KM-3035. Is there anything else I should know before I ...
            1. power down machine
            2. unplug power
            4. open machine
            3. attach board (in 3 pieces)
            4. close machine
            5. power up and configure
