Taskalpha 300i finisher issue
  • D_L_P
    Self Employed
    • Oct 2009
    • 1196
    I'm new to Kyrocera's but want to know if the DF-760(B) is the correct finisher for a 300i? This is for a new install and when I plugged in the 2nd finisher and got the same error "there is a problem with the stapler....." I wondered if there is some minimum firmware or wrong configuration or missed something on the setup?
  • LNorris
    • Sep 2008
    • 645
    is the internal finisher? there is no 760(b) that goes to this model. there are 670(b). check tech bulletin one
      • 23010
      If it's a CS-300i, you can attach a DF-670(B) or a DF-780(B)
      If it's a CS-300ci, you can attack a DF-760(B) or a DF-780(B)
      You always want to reload the firmware when adding an accessory. The machine will only update firmware for accessories that are currently attached, so any finisher firmware present will be out of date, and perhaps incompatible with newest versions of engine, main or MMI.
      • D_L_P
        Self Employed
        • Oct 2009
        • 1196
        Sorry, it's a Taskalfa 300ci with the external finisher DF-760.
        Thanks Blackcat, I was hoping it would be something simple (and free) like firmware and not a $$$PCB. I'll try that on Monday and let u know.
        • D_L_P
          Self Employed
          • Oct 2009
          • 1196
          UPDATE -
          The finisher is now working. I found a maintenance mode U906 that resets partial operation. I'm guessing it is similar to Canon's limited functions mode, anyway after executing this mode it booted up and everything was working fine.
            • 23010
            Originally posted by D_L_P
            ... I'm guessing it is similar to Canon's limited functions mode ...
            Exactly correct. =^..^=
