send documents from PC to hard disk of km 4035
  • dipakpatel
    • Sep 2010
    • 34
    Can anyone help,i want to send documents to hard disk of kyocera mita 4035 from my PC.
    thank you.
  • aabarnes1
    • Mar 2009
    • 620
    I don't think you an do this directly.
    Grant me the serenity to accept the things I cannot change.
      • 23008
      aabarnes is correct. You'll have to scan them into the MFP. No direct path. =^..^=
      • Jules Winfield
        • Jul 2009
        • 821
        What about sending a print job to be stored on the optional hard drive? Permanent jobs can be stored on the option hard drive, can't they?
        But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
          • 23008
          Private Print is different than a document box. Private Print jobs are in PCL or KPDL print language, and will clear immediately when the password is entered. These documents cannot be sent, since the scan card cannot use PCL or KPDL print language. A Document Box holds scanned documents as PDF, JPEG, or TIFF format, that do not clear when sent or printed. =^..^=
