kyocera mita KM 3050
  • Renuen
    • Aug 2025
    [Misc] kyocera mita KM 3050
    I have a problem with a Kyocera KM 3050. I have a two centimeter film toner points horizontal. 8 cm from above.
    The machine:
    Life count 570170
    maintenance count 170000
    I switch the transfer roller, no chance
    corona, no change
    I use a new developer, the points are darker
    I remove the developer and use the old one
    The points are very small and anemic
    Thank you very much for any help
    • 23010
    The spots that you are looking at are probably arc marks between the primary and the drum. You'll need to replace the drum unit to resolve this issue.
