I have checked both drawer feed assys for wear and found everything ok, I can hear the paper being lifted, it will make a copy every now and then. This is the same for all drawers, the by-pass works fine. Could this be a bad clutch? Thanks in advance. eric.
Royal copystar 3530 paper feed problem
What jam codes? =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
