help help please!!!!!!!!!!!!!!!!!!!!!!
  • kamongo
    • Jan 2011
    • 16
    [Misc] help help please!!!!!!!!!!!!!!!!!!!!!!
    hello
    Need help
    I have Kyocera copier km 4035,when i turn on I keep on diplays "Please wait...."but it will never come to Raedy to copy
    Please help on that
  • joelsa12
    • Nov 2008
    • 260
    i would think that it is either out of toner, has the wrong toner (Kyocera vs Copystar), or the toner drive gear is broken.
    • aragul
      • Dec 2007
      • 128
      Kyocera and Copystar toner are the same for these Falcon models. It's the printers that are different, and only because of a coupling.
      I've had a few Falcon 1s do this because of a dying fuser. The fuser would never reach or read the correct temperature, but I guess it was so close that it would never C-code out. Replacing the fuser fixed it.
        • 22999
        I've seen "Please Wait" on the Voyager & VoyagerE series when the document processor in not plugged in, or the lift plate spring is broken. Note: Don't plug in the document processor hot/live. Guaranteed you'll blow a board. =^..^=
        • spacedust
          spamanamamammmmm
          • 47
          I had that once, turned out to be the fax option.........
          weird i know, but turn off the machine and remove the fax option then power on.faulty fax.
          might help.
          • JustManuals
            • Jan 2006
            • 9838
            Just Manuals | The Internet's largest collection of manuals | Instant Downloads - Just Manuals
            Paul@justmanuals.com
            • aodtech
              • 194
              I second that it's probably the fuser. I've had this happen to a 3035. Does the heat roller actually get hot? To test this go to sim 162. This will stop the stabilization process and get the machine to ready. And you'll get fusing sans heat. Replacing the fuser should fix this.
              • kmteck
                • 37
                I think it needs a firmware update. You need to reload the firmware via CF Card
